Has any one on here fitted 2.3 v6 in to a nova b4?any good?or best to just put in c20xe?advice pics ect etc please
best off with a 2.0 16V, easier, as fast if not faster in most senses bar preahaps top speed but meh
v6 would be alot heavyer too am i correct in saying so?but would sound ace!!!!!!!!!!!!!!
been done plenty of times before but not worth it really due to the weight and with the amount of custom bits you have to make. having said that im doing it
Not much heavier than an XE, size is more of an issue as its deeper but do fit fairly easily.
Depends what you like driving.
doesnt have to be , then you can mount it slightly higher for the clearence insues underneithOriginally Posted by Ben
There is no clearance problems underneath its the slam to bulk head clearance raise it there and you will need to jack your bonnet up and it just wont sit right.
just got mine running with the cav motor and corsa epas, its feckin quick, beats a 400bhp pulsar gti-r on the strip
had it up 2 165 and backed off:D
what have you had done to it, coz i no the pulsars are quick as **** and 4wheel drive so no probs at all from a stop start
Originally Posted by slothsport1
