16sv is a carb engine
Meh, i only mean mk3 cavs Lol.Originally Posted by craig green
How many mk2 cavs do you see about, not many, so i assumed he meant Mk3.
Ye, mk2 1.6 cavs were big block as thats what CV you use for a big block conversion.
Old XE track car
i meant mk3, the 2 (in the code) reads as: c16nz2 for family 2. iirc the carb 16 is a small block, basically a gte motor with a carb and hei (high energy ignition) system, instead of injection, hope this helps,
sloth
I've never seen a 2 at the end of an engine code?
Old XE track car
or the simple way is to look at the rocker cover size,
sloth
