Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: 2.0 8v non start, please help!!!
  1. #11
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    was a 1.2 carb. i wired the pump up 2 the ig switch as a test.
  2. #12
    Jul 2003
    United Kingdom
    11,735
    have you wired the ig live feed to the fuel pump relay then
    if you have and your still not getting anything it could be the relay , can you change it for another
  3. #13
    Jul 2003
    United Kingdom
    11,735
    alos are you using the injection tank ?
    very advisable
  4. #14
    Banned
    Jan 2006
    11,720
    nope its a saloon so a gsi etc one wont fit, different filler pipe points, the pump was direct wired as a test. not the relay, soz 4 tha confusion
  5. #15
    Jul 2003
    United Kingdom
    11,735
    as far as i know the tank itself is the same ? thought it was only the feed to it that was different ?
    can anybody else shed some light on this
  6. #16
    Banned
    Jan 2006
    11,720
    i bought a gsi tank, and tool mine out, on the gsi, the pipes are at the side for the filler, but on mine they go out the back in the middle
  7. #17
    OMG! WTF? BBQ :) Lee's Avatar
    Jun 2005
    Newbury
    16,724
    It wont be a problem using a carb tank, the difference between them and an injection tank is they dont have an internal swirl pot, so you may experience some fuel surge on corners, but it wont effect the engine getting fuel!
    One thing i hope you HAVE done is put the metal injection fuel lines in?
    I assume the ECU is getting power?
  8. #18
    Jul 2003
    United Kingdom
    11,735
    the filler pipe is at the side yes ,and on a gsi tank the outlet to fuel pump is on the back in the middle , and the return is on the front in the middle
  9. #19
    Jul 2003
    United Kingdom
    11,735
    Quote Originally Posted by Bottlethroddy
    it will fella i know of a few people who have killed their XE's because the have ran carb tanks and when they have either ran low or heavy corners they have obviously ran lean and then just melted ****
  10. #20
    Banned
    Jan 2006
    11,720
    yeah runin nu high pressure lines. how do i check the ecu then?
