now then! ive just put a c20ne in a h plate salloon, the problem is it wont start. the fuel system pressurizes, the injectors are recieving their pulses, and theres a big spark, but it still wont start, please help as its doin my head in!
sloth
sloth
timin ok? id check that first if you've got spark and fuel
took enguine out of a cav, twas runin, put it in, not stripped owt down like
id still check it m8
fuel lines on the right way round?
ones got silver circle thingy=feed, right?
uthers to the rail.
????? ones feed ones return, simple. just swap em round and try it.Originally Posted by slothsport1
wrong way round mate
the feed goes to the rail and the circle thing your on about it the pressure regulator , that is the return
tried it, it still wont run, ive connected the ECU as oer the valvers.com but what i think is the fuel pump relay isnt actovating i.e no feed etc...
p.s this is near the 3 little multiplugs near the ecu.
ta,
sloth
what engine was in the car originally ,
you said it the first post that the fuel system is pressured , so your fuel pump relay must be working
