Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: carb
    Senior Member
    May 2005
    walsall
    118
    Default carb
    what carb will be better to run on my engine at the mo i have a 18cav carb on with a p/phead and manifold 4 branch ect will a 32/34 be better ???
    cheers ad :D
    4th year Membership Scab Club Member Dod's Avatar
    Sep 2004
    Co.Donegal ROI Currently: has no Novas...
    10,651
    What size is your engine? Everyones gonna tell you T40s so i'll beat them to it
    Go for T40s mate. ::
    I spent 90% of my money on Drink and Women, the rest I just wasted.
    Senior Member
    May 2005
    walsall
    118
    its a 16 gsi carbs are a bit costly at the mo tryin to get a house other wise twin 40s would be a must :D
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Lol,
    To start with rip that carb off, and put he EFI system back on :wink:
    The standard MPI system is miles better than a single carb, you will be losing power with that carb fitted.
    Either go t40s.
    Or put the MPI system back on.
    Sep 2004
    10,651
    Just leave it as an injected unit. Far simplier. As for the house, me knows. Signing the mortgage on Thursday!! ::
    Jun 2002
    Cleveleys, Lancashire
    4,104
    thirded, EFI is the way to go on that motor unless your gonna go for ITB's
    single carbs are a useless waste of time and when the engine comes with EFI theres no point removing it to fit some shite old carb
    and dont start with the crap that its difficult to wire in an EFI system, its 6 wires a fuel pump and tank, not the most challenging of operations ever
    Senior Member
    Jan 2004
    299
    you can put mre power than 2x40's whit EFI bur you have to do some thing inside it
    Senior Member
    May 2005
    walsall
    118
    was told today that wirin the gsi loom in is a full strip down in and out of car but surly u can patch it in to the sr and as for the fuel pump im runinn a facet fuel pump and filter king press reg any idea how to wire up gsi loom and obviusly ill have to run all the ignition system to
    cheers ad :D
    Sep 2004
    10,651
    Quote Originally Posted by Aragorn
    Temper temper. Just think, we all need help with things as well, something we're misguided and need help from others, please bare that in mind before shouting at us and making us cry like bitches, sniff, sniff!!!! :oops:
  10. #10
    Jun 2002
    4,104
    the EFI loom needs an ignition live and a permenant live which can easily be obtained from the battery and ignition barrel
    it also has outputs for tacho on dash, engine management light and fuel pump
    the facet redtop is no use for an EFI engine as its not high enough pressure
    either find a GTE/GSi/SRi tank and GTE/GSi/SRi pump
    or get a 1.2i tank and fit a mpi pump from a cav/astra/corsa etc to it
    the engine loom is self contained, it connects to all the injectors/sensors/dizzy/coil etc, the only connections back to the car are those listed above which are on a multiplug that sits next to the wiper motor
