the 16SH is small its comes from a kadett.
don't forget the cavalier is called the Vectra on the continent i believe.
is a Kadette a kadette or an astra over here?
the 16SV has the same compression ratio to the 16SE the difference is that the SE is Injection and the SV is carb'd, i aint sure wot my lump is out of but its a good clean engine, and with the 1.4 cylinder head and piper cams it goes like stink
Becuase you said you have piper cams.....
......Originally Posted by lashednova
cams is a plural hence 2 or more,
an 8V only has one cam, so you have a piper cam.
'cams' is plural, so means you have more than 1, e.g 2
'cam' just means 1
Thats why he thought it was the DOHC 16v engine :wink:
*Edit* Doh, beat me to it!!
Fuckin hell them responses are almost identical!!!!!
:: Well you know what they say about great minds............
I didnt know you had to be so correct wen sayin..... :|Originally Posted by lashednova
so ok yes it is a piper cam 270, considerin as on the box says 'piper cams' wen it had 1 camshaft in it
