Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: 1.6 16v problems
    Jan 2005
    york
    368
    Default 1.6 16v problems
    i drove it today and it idles perfetly!, but the rev limiter kicks in at 4k, wots that all about? any one heard of this before,possible ecu fault?
    cheers ROB>
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Sounds like its in limp home mode. Anyy ecu light?
    Jan 2005
    810kg 300+bhp 6 spd nova turbo
    1,281
    mine did this on the way back from pv show, the manifold had broke at the bottom making me loose loadsa power and when it was warm it limited at 4k, ecu fault id say
    Jan 2005
    york
    368
    Thought it mite be something lke that,i hope its not a big prob and it can be reset.
    Cheers ROB>
    Senior Member
    May 2004
    N. Ireland
    428
    yea stick a code reader on it to read fault and clear it.
    Its prob air temp or sometimes a cam sensor- which actually is a phase problem due to the blet being slack
    Steven
    Member
    Jul 2005
    my bed for obvious reasons ;)
    57
    cam sensor this happend to 2 of my friends with 1.616v gsi's, the sensor kicks in at 4 and a half k revs!
    only happned when they had the engine fitted tho!!
    Jan 2005
    york
    368
    Right then, got it sorted, i missed the single pin sensor off.........knock sensor :D anyway, pluged it in and it reves right round now, thanks for the advice guys,
    Got a now problem now tho, it wuz ok for a day but now it idles at 3k once its got hot! wots that all about? any more help would be ace. cheers again guys.
    thanks to Joff for the diag plug and checking it over.
    Jan 2005
    1,281
    veichal speed sensor?
    idel control valve?
    Jan 2005
    york
    368
    Quote Originally Posted by jamie gsi16v
    idel control valve?
    erm i dont have the speed sensor Jamie,the one on the gearbox?
  10. #10
    Jan 2005
    1,281
    yeh you need this on and wired up correctly, i didnt n mine had a mind of its own, sumtimes it wouldnt idle then it wud rev its socks off.
