Results 1 to 6 of 6
Thread: *HOW TO* Blanking off E16SE EGR
    Moderator Mazz's Avatar
    Jun 2005
    Stafford.........Drives : Audi A4 + NOS Nova GT'XE
    6,657
    1 Post(s)
    Default *HOW TO* Blanking off E16SE EGR
    "The EGR valve helps your car more efficiently and completely burn fuel by recirculating a portion of your exhaust and running it through the combustion process again. This results in a cooler, more complete burn of the fuel which decreases you car's noxious emissions by prohibiting the formation of some harmful gases."
    As a result, they get carbon'ed up and stop working, causing rough/lumpy idle and revving. By doing this you are by-passing the EGR valve.
    They can be replaced, but are quite expensive, so after this thread and some googling I found you can blank them off. Vauxhall actually sell EGR blanking plates for some cars!
    I tried the coca-cola (well Dr.Pepper tbh!) methold for a quick test..
    Get a drink's can and consume the liquid goodness!
    The EGR valve is hold on by 2 x 10mm nuts..
    Remove it and make a template using the original gasket.
    And re-fit! Simples
    After doing this, the ECU was still on but revving up and idled and lot better than before, but after a long run the ECU light went off and has stayed off.
    EDIT : Leave the EGR connected/piped up too!
    (┌∩┐(◣_◢)┌∩┐)
    Jun 2009
    Newark
    4,682
    Well done mate, don't want to piss on your fire though but we have had the alloy can material melt from doing this... I normally use a piece of plating steel like a sill repair panel we seem to have lotsv of
    Jun 2005
    6,657
    1 Post(s)
    Yea, as i said this was just a quick test - just to see if was better, which it was!
    (┌∩┐(◣_◢)┌∩┐)
    Dec 2008
    Coxhoe/co Durham/ United Kingdom
    2,794
    i like all be doing this to mine
    Jan 2003
    SOMERSET
    19,510
    Ditto the above. I did it with a piece of 3mm alloy shaped to the gasket & removed the valve entirely.
    Assuming this is on an E16SE, you shouldnt suffer any fault codes as the EGR is in no way linked to any sensor/loom. Just put a screw into the vac pipe or blank it at the source.
    Jul 2008
    Unknown
    9,635
    ford transit burns through coke cans on the egr blank but i used 1mm alloy so probs lasts alot longer.
