I got some second hand kenwood 6x9s,KFC-7176 or something such,problem being, I aint got no template for cutting mdf for them.Are all 6x9s able to fit in the same template?- or all kenwood ones?
pretty much all 6*9's have the same template. if you have a spacer ring then use the inside of that as a guide happy cutting. get the edges real smooth
nice one cheers, I found out the fella lied to me, they aint 6x9s,theyre 7x10s!-and retail at around ?80, thanx for the advice, will give it a shot
Wikkid, those 7*10's kick ass, I wanna get some, seen 'em for 70 somewhere :D
if you do it right you dont need subs unless your a fecking bass monkey
-My 7x10s cost me ?25 second hand!-KFC-7176s. The only thing Im a bit worried over is my head unit is 4x35 watts, and the amp is only 4x40watts, so is it really worth wiring in the amp for them or should I use it to power some tweeters or mids?- what about bridging?-is it using both positve of 2 channels to one terminal, and both negatives to another, or just a seperate channel to each?
use your head unit!!!!
