Results 1 to 3 of 3
Thread: !!fuel pressure reg need quick answer!!
    Member
    Feb 2005
    40
    Default !!fuel pressure reg need quick answer!!
    will this regulator be ok if changing injection to webbers carbs on nova gte?
    About this product
    Adjustable low pressure chrome regulator with sprung loaded bezel adjustment. 1 to 5 psi supplied with unions.
    http://www.demon-tweeks.co.uk/catal...P088&tlgrp=M006
    Moderator burgo's Avatar
    Apr 2003
    kettering
    22,773
    11 Post(s)
    yes as webres run at 3psi
    Jun 2002
    Cleveleys, Lancashire
    4,104
    the regulator doesnt have a return
    your nova gte fuel pump is designed to run with a constant output flow rate and trying to regulate that without a return feed WILL damage something, either the pump will give out or the regulator will fail and shove 5bar into the carb float valves
    so either swap the pump for a type of pump that is designed for use in these circumstances or get a regulator with a fuel return
