Results 1 to 10 of 10
Thread: Putting a 1.2 head onto a 1.4 SR
    Member
    Nov 2004
    66
    Default Putting a 1.2 head onto a 1.4 SR
    I have a full 1.4 SR engine and a full 1.2 engine so which bits will i need to swap to make it fit? has anyone had first hand experience of doing this and what advangtages can be had?
    thanks
    Dave
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    a) the sr and non sr engines are the same (unless your in the early years of novas then there was a mild difference)
    take the head off the 1.2, get a 1.3 inlet manifold and then fit those parts to the 1.4 engine. you should have a bit more go from the off then.
    other than that it should all be the same (dont forget to keep the 1.4 dizzy,coil etc)
    Mar 2003
    HMP Dartmoor Hobbies: Running up walls Dislikes: Bling
    2,886
    this 1.4 sizzy/coil thing comes up again. Whats so good about it compared to the 1.2 coil/dizzy?
    Also use the 1.4 cam. The 1.2 cam won't fit the 1.4 dizzy i think.
    Nov 1999
    35,414
    18 Post(s)
    the 1.2 unit is big and a lumbering
    and no one has really used one in "hard use" applications where as we know the 1.4 setup works well.
    Mar 2003
    2,886
    i see.
    so is the 1.4 dizzy Delco Remy or is it still Bocsh?
    Jun 2002
    Cleveleys, Lancashire
    4,104
    1.4 is bosch HEI system
    1.2 and 1.3 are a delco system which isnt as good
    Member
    Nov 2004
    66
    righto, cheers. I plan to run a twin 40's from a sport aswell if i can find them so which inlte manifold will I need? Will using a GSi exhaust manifold and downpipe make any difference aswell as a GTE/GSi cam??
    Mar 2003
    2,886
    Black dizy cap is Delco right?
    and red is Bosch?
    the only problem is running a 1.4 dizzy is that you need a 1.4 cam, as the 1.2/1.3 cams don't work with the 1.4 dizzy, as someone on here found out. (forget who).
    Member
    Nov 2004
    66
    when i take the head off, it just unbolts and bolts straight back on with new gasket and strethc bolts right? No valves or anything to refit is there??
  10. #10
    Mar 2003
    2,886
    no. you'll have to undo some water pipes and take the tension of the cambelt (water pump or tensioner whichever) to takeit off the pulley.
    best really to get a Haynes manual as it tells you exactly what to do.
