Results 1 to 10 of 10
Thread: Running very hot???
    Junior Member
    May 2004
    Scotland
    6
    Default Running very hot???
    Alrite folks, 1st post on this, been reading here for a while and now need some info for myself. Basically I have a 2.0 16v red top in my nova, the water (header bottle) under the bonnet is cracking from the pressure thats building up in it because of the boiling water in it after a run in the car. Its pretty weird this bottle has the normal 2 pipes (1 going into the bottle and 1 going out to the radiator. This is normal aye, like my 1st valver nova. Only this one has another thin pipe bored into it that comes from the back of the head ish place that gives a constant feed of water to the bottle when car is running???? I can hear pressure coming out the bottle when I pull up and when I slacken off you know what happens. Bubbling/boiling water fires out wi a vengence.
    Any ideas as to problem and how to repair would be appreciated
    Cheers in advance
    John
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Could be a head gasket on its way out, which is pressurizing the whole system.
    Has the coolant been going down quickly, which would explain overheating of your engine.
    Senior Member
    May 2003
    Derby
    960
    I know nothing about 2.0l novas but ive had a similar problem with my gsi recently,
    Try replacing the header tank cap as there is a breather on the other side of it. Mine was blocked and causing the pipe that comes out of the head to the radiator to blow up like a baloon.
    Check the radiator is working also and flush the system.
    Jan 2002
    Gloucester
    865
    Sounds like a good idea. I'd fit a new cap then rad flush the thing, go for a drive. dump it, flush it, dump it again. If it's still overheating then the head gasket is looking likely.
    Junior Member
    May 2004
    Scotland
    6
    Default Overheating
    I personally think the head gasket is the problem, if it is how much is should I expect as a bill from a garage to repair this properly.
    Also when I look into this bottle at the water, theirs little tide marks with little black flakes all around the edges of the water????
    Senior Member
    May 2003
    Derby
    960
    I'd still change the cap first mate.
    When i had the problem i was getting brown merky sludge in the header tank and afew told me that that was the headgasket as oil was mixing with the water.
    But, once i'd change the pipe & the cap and flushed the system through its been nearly 3 weeks and theres no sludge and its been running fine.
    Have no idea how much a garage would cost to do a head gasket on a 2.0l
    This is what was happening on mine cuz of the blocked header cap.
    Mar 2003
    HMP Dartmoor Hobbies: Running up walls Dislikes: Bling
    2,886
    is ur red top a coscast head?
    User _JH_'s Avatar
    Nov 2002
    South West Wales Drives: 2.0 8v Grasser
    955
    change your thermostat also.
    Junior Member
    May 2004
    Scotland
    6
    Default Coscast
    Yeah its a Coscast. Going to check the thermostat tomorrow and hoping its just that thats seized and in need of replacing. dont really fancy paying for new head gasket. Cheers for the answers
  10. #10
    Nov 1999
    St. Asaph Drives: Honda S2000 Drives: Passat TDi Drives: 106GTi Drives: 106XLD Drives: Swb Transit
    6,986
    never take the cap off this just causes it to boil over
