Results 1 to 3 of 3
Thread: Wat amp should i get 4.......
    Junior Member
    May 2004
    Rotherham
    7
    Default Wat amp should i get 4.......
    I'm bout 2 buy 3 900watt 12" sony Xplod subs in one box off my but i dont know wat amp ill need 2 power them coz my mates only got 2 of them in single boxs and hes powerin them with a legacy 1500watt so wat will i need
    cheers Mic
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Default Re: Wat amp should i get 4.......
    Quote Originally Posted by Mic
    cheers Mic
    Did you say 3-900watt 12" subs, it is gonna be one loud install. Probably rear window breaking,LOL ::
    Well i would get either a 4ch amp bridged to 2x2channels to power 2 subs, and then a 2ch amp to power the remaining sub.
    Or you could just get 3x 2ch amps, using the 4ch to power two subs would probably put a lot of strain on the amp.
    But using three subs is gonna put a lot of strain on your battery and car itself. Make sure you sound-deaden the boot etc.
    cage it and brave it!
    Sep 2003
    e.port, near chester
    5,293
    before you start going way over your head.
    you really need to get a heavy duty battery, bigger alternator (td nova one) and i would recomend a power cap. this lot alone is going to set you for atleast 200-300.
    amp wise, if the money is there then i would suggest
    3x 800 mono block amps.
    if it aint, then as suggested above, a couple of cheapish 4 ways bridged into 1.
    but the danger is?
    a poor amp and under powered will make the system sound pants.
    alternative, sell one of the subs. 2 will be loud enough unless you are aiming for a custom boot build and spl shows
    Light travels faster than sound. This is why some people appear bright
    until you hear them speak.
    "EVERY LITTLE HELPS"
