Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: amp over-heating probs
    Member
    Jun 2003
    MIDLANDS
    66
    Default amp over-heating probs
    any of you get this problem much??
    My amp did it today for the first time and i wanna no if you lot get it much.
    cheers guys.
    ps i got my gain on the amp a good way up too. i dont really wanna turn it down much cuz im bass mad.
    cage it and brave it!
    Sep 2003
    e.port, near chester
    5,293
    as long as the amp is in a well ventolated place, then it should be ok.
    where and how is it installed (how being, upside down etc)
    Light travels faster than sound. This is why some people appear bright
    until you hear them speak.
    "EVERY LITTLE HELPS"
    Member
    Jun 2003
    MIDLANDS
    66
    kind of side ways on the back of the bass box. is this a problem??
    Member
    Jun 2003
    MIDLANDS
    66
    and its in the boot
    Sep 2003
    5,293
    so the amp is sitting on the side of the box in the boot. there shouldn't be a reason for it to over heat as the hot air from the amp will be able to rise.
    mmmmh
    i can only think that it was (well, here it was) hot today and you are playing the tunes very hard!
    or
    you may have the wrong sized fuse in the power cable causeing too much power to the amp and allowing it to over heat before it blows up. what fuse is on the amp and what have you put up near the battery?
    Member
    Jun 2003
    MIDLANDS
    66
    the amp is sittin on the back on of the bass box and facing towards the back seat and very close to. not very well ventilated at all to be quite honest. i just been told too, that amps are best flat as the air rises straight up. whereas now, the air is rising into itself
    tut tut
    what you think ???
    PS youve been a great help srs !!!!!!!!!!!!!
    Sep 2003
    5,293
    :oops:
    ohhh i have gone all shy!
    i put my amps on the back of my seats, and the bass box hard up against it. i have never had a problem, so i dont think you should have either.
    yes, amps are best laid flat for the reason you said. but this is practicle if you do a proper install or secure it in some way.
    as long as the hot air rises and does not get trapped in the unit (ie. upside down or in a sealed inclosure) then there shouldn't be a prob. i would check the fuse ratings. remember the heat is generated by the power and work rate the amp is doing!
    Senior Member
    Dec 2001
    essex
    242
    Where is the best place to put the amps so they are well ventolated place
    I got one on side of the sub box as its built in.
    other one on back of the seat...
    Are these a good place.
    Member
    Apr 2004
    50
    On the side is generally ok, you normally only have problems if the amp is upside down.
    If your getting overheating, you should add some fans to the system
  10. #10
    Jul 2002
    7,862
    wood is an uinsulator, so it is a bad place to put the amplifier. Use 5mm metal spacers or something similar if you must mount it there.
