I might think of getting components as your saying they are better.
What onces are best?
Where would you put the 2 little speakers...
What are the 2 long things on the left of the pic?
Witch once do you think are best as there the 2 im look at
if you put in the power rating then we will be able to say which are the better ones mate.
as for the long bit, well that helps seperate the bass and treble, making sure the correct speakers gets the right hertz
Light travels faster than sound. This is why some people appear bright
until you hear them speak.
"EVERY LITTLE HELPS"
as he sed plus heres a link to components in the doors
http://www.novaload.net/forums/viewtopic.php?t=91171
Peak Power 120WOriginally Posted by srs1
30W Nominal Power
Frequency Response: 50Hz-21kHz
Sensitivity: 90dB/W/m
FIRST PIC
Integrated Component System (170W peak power)
SECOND PIC
Where would i put the 2 long things in the second pic
you can put it any where mate, i would suggest on the under parcel shelf at the front of the car.
you can also build them into your door card as sort of a feature 8)
Sounds good.. But if i get then i would just put them under the dash....Originally Posted by Dpnova
a good place to put the tweeters(the little ones) is on the a pillar or under the component angled out so that the sound from the component is carried up to the ear buy the tweeter( its all to do wiv sound imaging)Originally Posted by baha_guy
