Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: turbo charging webers
  1. #21
    Senior Member
    Jan 1970
    Bromley, Kent Drives: Mazda 323F Building: Mental Beetle
    337
    Quote Originally Posted by mikeoxford
    Quote Originally Posted by Derek Zoolander
    mmm. grill mounted carbs .
    your not the only one that thought that :: i immediately thought of the GM touring cars that ran c20xes with the heads on back to front - or whatever they were
    Am I the only one here who see's a slight problem of the rad being there? :wink:
    Chris
  2. #22
    User BigRuss's Avatar
    Aug 2003
    Sunny South Wales
    586
    I agree it could be done by conventional turbo-charging method (Blow through) quite easily. You would simply have to use an Irmscher 1300 Sport air box as a plenum-chamber on twin 40's or 45's.
    Mount a turbo on the exhaust manifold put the charge through an intercooler and pipe it directly to the Irmscher air box :D
    If only someone had a full sport carb set up for sale :wink:
  3. #23
    Nov 1999
    West Midlands Drives: Work In Progress
    7,742
    im in the process of sending an imrscher airbox away to the chromers....
    i can hold onto it for time being if you want to turbo it for me 8)
  4. #24
    User _JH_'s Avatar
    Nov 2002
    South West Wales Drives: 2.0 8v Grasser
    955
    I'd like to see a turbo'd carb nova too. perhaps just an sr with the dmtt I mentioned earlier. Its really got me thinking. cut rubber gaskets using the old ones as templates, then just pull a turbo of a td car down the scrappy and weld it to mainfold etc. nice sunday afternoon bodge job. then a quick piddle around with some jets and a gas analyser
    hmmm. the old 1.0 pushrod nova that did so well in the field last year against my old fiesta might have an upgrade this year ::
  5. #25
    Aug 2003
    Sunny South Wales
    586
    No prob with the rad, just move the bottom of it as far forward as possible, I put an RS Turbo engine in to an XR2 8-9 years and had to move the rad forward and cut clearance in to the X-member for the down-pipe.
    Where there's a will there is a Way :!:
  6. #26
    Senior Member
    Jan 1970
    337
    Russ,
    Nice idea except for as soon as the turbo made boost (I think it's about 4 psi) the fuel gets forced out of the butterfly spindles and a few other places. To use 40's in a blow through configuration you need to get them taken apart and machined to take some extra seals to stop them doing it. You also need to install modulator rings and shit like that, but by the time your up to that you really need to start reading books on the subject.
    Chris
  7. #27
    Senior User Premium User
    Jan 2004
    kent
    1,967
    :o now theres an idea for my 1ltr ! Turbo it (wud b good if it can b done)
  8. #28
    User _JH_'s Avatar
    Nov 2002
    955
    Quote Originally Posted by Chris_W
    Chris
    why no! a bit of pipe work and it would soon be out of the way. bonnet maybe? with its own scoop? :D
  9. #29
    Aug 2003
    Sunny South Wales
    586
    HHHHHHHHHMMMMMMMMMMMMMMMMMM!!
    I see your point, I for one would have to lower the compression to say 7.2-1 and bang at least 25psi in to it. I have a reputation to uphold :twisted:
  10. #30
    Senior Member
    Jan 1970
    337
    Why not just stick some NOS in it instead of lowering the comp. ratio ?
    Chris
