Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: !!!!!!!!!1.6 GTE engine wiring help!!!!!
    Member
    Jan 2004
    51
    Default !!!!!!!!!1.6 GTE engine wiring help!!!!!
    I need to know where the following wires go on the 1.6 GTE engine hence the topic. Can all you 1.6 GTE owners help this temporary 1.6 wannabe out and take a look for me? I really need to know and would help me a great deal.
    The link for the pic is ...
    http://www.sighost.us/members/bluemorbo/wirespic.jpg
    Cheers folks!!
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    it goes something like this......
    make use of all of your original wiring for ancillaries(senders etc.) & the starter motor/alternator circuits
    then you need to connect the big red one to the battery(use lug on starter motor)
    then connect the black one to the ign. +ve circuit (trace the black coil wire on your old loom back and run a new wire from there.
    the red/blue needs running to the injection pressure pump, which needs an earth.
    run the brown/white wire to either the correct telltale on the dash, or if you are fitting it with your original dash, just link it into the choke light.
    there really are no other wires, all of the loom on the engine is self contained.
    enjoy
    Member
    Jan 2004
    51
    Default reply to 1.6 gte wiring
    the colours of the wires i have are
    Red
    Green
    Black
    Red&Black
    The red and black will be the same but what are the other 2 do you think?? Cheers for your help to.
    Senior Member
    Apr 2003
    Billericay Drives: Nova 2.0 Turbo
    1,191
    green is for the rev counter. connect it to the -1 terminal on your coil.
    black and red goes to the solenoid on the starter motor.
    Member
    Jan 2004
    51
    Default 1.6 gte wiring
    there is already a black&red wire going to the starter motor solenoid? Do i add this wire as well or instead off becaue the black&red wire is from the wiring from the car??? Is everyone certain the thick red one goes to the battery because when i try starting it it tries to keep on starting when it is connected?? Where is the wire for the 'water pressure pump' if i have that right?
    Senior Member
    Apr 2003
    1,191
    not sure then mate.
    have you tried the haynes manual?
    will defo be in there
    Junior User Club Member
    Jul 2001
    Devon, Newton Abbot
    62
    Are putting a 1.6 in a carbed shell? because i have done the same before.
    Is that pic showing the plug/socket from the loom used with the bosch ecu? if so, i had 4 wires, and this is where i put them:
    thick red - +12 on the battery
    red/blue - fuel pump*
    black - into fuse no1 linked to h/lights*
    green - rev counter behind dash
    *I might have these 2 the wrong way around, it was a while ago.
    i ran 3 xtra cables from the socket, past the battery and into the cabin, noting the color difference.
    Hope this helps.
    Senior Member
    Apr 2003
    1,191
    red and blue is for fuel pump. But why did you wire the switched live to your headlights?
    It goes to the ignitions (on coil)
    Jun 2002
    Cleveleys, Lancashire
    4,104
    the coil ignition black aint the best one to use
    some carbed engines - early 1200 and 1.0 notably have a resistance wire in the feed to the coil to stop it burning out - u should run the black wire inside the cabin and connect it to a good solid ignition live either in the fuse box or at the ignition barrel itself
  10. #10
    Nov 1999
    St. Asaph Drives: Honda S2000 Drives: Passat TDi Drives: 106GTi Drives: 106XLD Drives: Swb Transit
    6,986
    Quote Originally Posted by Aragorn
    prove it... i couldn't find it on my 1.0 and it's not shown on the haynes wiring diagrams
