Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: 6x9s
  1. #21
    Jan 2004
    1,380
    does anyone know anything about powercaps
  2. #22
    Senior User Premium User
    Jan 2004
    kent
    1,967
    Default 6x9's
    soz m8 only thing i know about power caps is they r used to boost the signal i think so the amp so it runs better(don't quote me on that tho coz cud b wrong)
  3. #23
    Jan 2004
    1,380
    i thought they where for the power feed
  4. #24
    cage it and brave it!
    Sep 2003
    e.port, near chester
    5,293
    powercaps are designed to give back up power to your amp, so if your car is not running the alt, the powercap gives the extra power. this meaning that your amp will have consistant power going to it. (no flat spots)
  5. #25
    Jan 2004
    1,380
    how would you wire it up to the amp then
  6. #26
    Sep 2003
    5,293
    the power cap sits after before your amp. what happens is, the power cable feeds the power cap then that feeds the amp, this way the power gets the power first, so when you get a flat spot the power cap feeds extra power to the amp via the + feed to the amp.
  7. #27
    Jan 2004
    1,380
    so it just connects up with both feed and out put togeither on the top of the power cap
  8. #28
    Sep 2003
    5,293
    power cable from battery to pos on powercap, neg off powercap to pos on the amp/or to the fused block connector (if running more then one amp)
    you really dont need a power cap unless you are doing a serious install
    more then one amp
  9. #29
    Jan 2004
    1,380
    1 1000wamp and 1 450 w amp
  10. #30
    Sep 2003
    5,293
    heavy duty battery and a better alternator will be needed too. then a 1 farrad power cap should see you right.
