Right i've got a 1.2 carb and the bottom end has gone again so i'm putting a 1.4sr carb (14nv) in to.
Is it possible to use the carb and ignition system from a 1.4 astra engine?
As i can't be bothered to try and wire the nova 1.4 sr up.
u can use your 1.2 stuff.. do u mean c14se
the c14nz is centre point injection only 60 bhp
So all i got to do is change the main jet in the carb for a 1.4 and change the camshaft to a slot drive.
The Haynes says the 1.4 carb engine is 14NV.
Single point injection is C14NZ.
Multi Point Injection is C14SE
