Will a VDO fuel gauge work with a standard nova carb fuel sender? Looking at this route for my rallycar
Does it come with it's own sender or expect you to supply the necessary feed?
See if you can find a manual on what it needs. I have a hunch the Nova sender can work back to front to aftermarket stuff leading to a backwards gauge.
With an aftermarket fuel level sender bolted into the tank, I reckon it would work fine. House has been playing with fuel level senders recently, if you drop him a message.
You can order a correct one from vdo marine. The normal tube and float types are wrong.
