What coil packs are people using with a highly tuned c20xe ? what plug leads etc?
coil pack brackets/mounts?
im thinking of changing from a H/H ignition kit to nodiz.
I use the x20xev coilpack on a home made mount . X20xev leads and rs turbo plugs (9's) on my let .
With omex it worked straight off the ecu drivers but with megasquirt3x i have had to fit an ignition module 7pin bosch type as i had the drivers removed from my ecu .so it is set up logic for smart coils . X20xev is what most people run
Tucked away round the back
Sent from my CLT-L29 using Tapatalk
Cool, thanks for the help.
With noidz / omex etc you wont have to worry about an ignition module you can just run the coils direct from the ecu . Its just that i didnt want high current interference inside my ecu from having ign drivers in there so i opted to run an external module . The x20xev coil has a +12v in from a relay and then the 2 signal wires from the ecu very simple to wire into stand alone
