It's been a long four years since I took my steering wheel off, now I'm getting to the point of buttoning up all the little jobs, would anyone WIP their horn push off and take a pic for me so I can see how the wiring goes together.
Cheers Nick.
Cheers Nick.
Anyone help me out with this? I think I'm missing some wires that connect to the horn push
Your horn contact should look like this. Then the red wire connects to the tab on the back of the horn push.
Without being with the car I cannot remember if there’s anything else
So it's just the one wire, I should be able to knock one of them up cheers
Does the spade connector connect to the washer on the steering column that has a tab on it?
No the black plastic contact ring clips into the steering wheel base. The wire clips to the horn push. Nothing is wired to the column. The contact is made from the pin on the column coming in contact with the metal on the back of the ring. Il get you a picture of the back of the ring.
Ahhh I don't have this bit, I'll have to try and find one.
Thanks
