Results 1 to 6 of 6
Thread: C20LET fuel pipes/hoses
    Club Member Club Member
    Dec 2004
    Edinburgh
    222
    Default C20LET fuel pipes/hoses
    My fuel pipes are 10 plus years old and I want to replace them. The current ones are a bit of a bodge, original ones from a vectra I think joined at the bulkhead to hoses running to the original petrol tank with submerged pump.
    Can anyone recommend a better set up, ideally I would like no joins for supply and return to reduce chances of a leak. Noticed some braided ones on eBay from abroad but again these are only 1m long.
    brotton , saltburn by the sea
    1,877
    Go to your local hose place mate to do the job properly id advise getting teflon and fitings after your pump and just get good quality from the tank to the pump as alot of super unleaded fuels contain methanol . I had my full set of hoses made custom to my car all in 13mm internal teflon braided (huge) and an10 fittings aswell as elbows n what have you for the pump . Cost around £140 but will never need doing again. Probs he half the price in 8mm or what ever the standard size is.
    May 2016
    147
    Someone mentioned to me that corsa b plastic lines are a good fit. I have an spi tank like yourself and will be changing them for corsa ones soon
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Yes Corsa C lines I've used on my c20let - easy to work with and modify and are plenty beefy enough.
    Corsa B (later models) will be the same too
    Dec 2004
    Edinburgh
    222
    Have been in touch with pirtek to get a quote. Was not aware about Corsa b/c lines. Do you know what engine sizes are compatible
    Thanks
    Sep 2012
    Sutton, Surrey
    3,752
    I'd imagine you want them from an mpi corsa b as the spi stuff ain't as great. Any petrol corsa c should work too
