Hi all , I need to replace my hub , nova has had the big block hub conversion done, any idea what the hub is off , so I can get one order , replace the bearing lase week , (Audi 80 one used ) any help appreciated
ta Ste . 👍
ta Ste . 👍
Will be a big block one so, mk2 astra 1.8 upwards cavalier 2.0 ect
They are slightly machined too, there is a guide on here explaing the ins and outs
Milly is right, if you're using Audi 80 bearings then it's the standard Astra hubs, these are an off the shelf item with a bit turned off the back of them I believe.
There might be some part numbers in my thread somewhere.
Thank you gents for the help , got them orderd , hopefully have a tinker over xmas .
Kind regards . Hope every one has a happy xmass .
With the astra hubs you still need to change a little on the hubs, otherwise it will be 4mm offset, and the brake will not fit.
Missed at that time to take photo from the issue.
https://photos.app.goo.gl/vqnxc93gwr3sfXzt6
Here this was the unmachined, and after that made the modification.
This is the picture from the other side pushed in the right position: https://photos.app.goo.gl/yMxBCAac4syhL58M9
