Results 1 to 4 of 4
Thread: First engine conversion
    Oct 2018
    Driffield
    2
    Default First engine conversion
    Hi there
    I've just bought a K reg 93 1.2i Nova. I'm looking to do an engine swap. I'm currently looking at a Calibra 2.0 8v from an early 90's model. I'm aware of certain things I'll need to upgrade ie: bigger welds in engine bay, fuel tank, fuel pump, suspension and brakes. I've got a friend with 2 full complete Cavalier legs (same era) buried away somewhere, but wondered if anyone knew if A: will these be sufficient enough and B: are they a straight swap, before I start digging around for them.
    Thanks
    brotton , saltburn by the sea
    1,877
    You don't have to change the chassis legs .
    Just a notch or dent for the alternator pulley but that's about it buy or make some engine mounts . Buy some drive shafts . If your just running standard power I wouldn't even bother welding the bay . I never have on a road going car and never had a problem .
    blackpool
    3,415
    My 2ltr 8v nova was fine without being stitched. Did do it when fitted the let though .
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Here’s a good read for you, it will help understand what’s needed for the conversion.
    https://corsa-novatuning.nl/conversi...-0-8v/?lang=en
