Results 1 to 6 of 6
Thread: E16se ignition timing
    blackpool
    3,414
    Default E16se ignition timing
    My e16se is running rough so iam go na check the ignition timing. I've got my self a timing light what should the e16se be set at on the ignition side? Cheers
    blackpool
    3,414
    Anyone help?
    Sep 2008
    Bridgwater
    12,248
    Haynes manual?
    blackpool
    3,414
    Could only find 1.3 engine. Unless Iam blind .
    Club Member Club Member
    Jul 2008
    Greenhithe
    1,614
    Have you tried connecting the light to number 1 plug, starting it. Then you can undo the supporting bolt that holds the dizzy and then slowly turn it until the lower pulley mark lines up with the timing pointer. This was the issue I had and now is much better for me. Unless the process is different on your engine to the the 1.3/1.4 8v
    blackpool
    3,414
    Sorted I've found it should be 10 ° btdc at idle.
