Results 1 to 9 of 9
Thread: Last electrical issue I promise!!
    Club Member Club Member
    Jul 2008
    Greenhithe
    1,614
    Default Last electrical issue I promise!!
    This is more of an annoying indicator problem. All bulbs are new along with the Corsa b stalk. When using the hazards the indicators flash at normal speed. When using the stalk in both directions they flash fast. I assumed it was my previous Corsa b stalk which I’ve had for years but replaced it today and it’s still the same. I tidied up the side repeater earths a few weeks back as one didn’t work at all so they are good.
    Any other ideas?
    Junior User
    Oct 2012
    Kinross, Scotland
    85
    Front and back working on each side?
    Jul 2008
    Greenhithe
    1,614
    Yep
    13,604
    Did you fit normal bulbs? LED bulbs for example can cause this
    Jul 2008
    Greenhithe
    1,614
    All standard Halfords job bulbs. Still wouldn’t explain it working fine when the hazard is pressed.
    I fitted a diode to the hazard loom for theft prevention. Could that be an issue? But as again the hazards work tho.
    13,604
    The one way diode thing wouldn't affect it I don't think. Weird. Do they speed up even more if you unplug one of the bulbs or stay the same rate?
    Dec 2013
    Kings Hill, Kent
    1,889
    I'd replace the flasher relay.
    Jul 2008
    Greenhithe
    1,614
    No change to speed with bulb missing. In terms of flasher unit, when I first tested the indicators the dash light stayed a solid green (didn’t tick). When I removed it, gave it a tap and a clean it then started working. Could be an issue I guess
    Jul 2008
    Greenhithe
    1,614
    So changed flasher relay this morning and it fixed the problem. Top stuff!!
