Results 1 to 5 of 5
Thread: MOT emissions failure
    User Club Member N0V4 JACK16's Avatar
    Mar 2010
    Preston lancashire
    287
    Default MOT emissions failure
    The sr failed it's MOT today on CO emissions. The bloke said the carb needs tuning as it's running far too rich. The carb is a weber 32/34.
    Do any of these jets allow for the emissions to be dropped?
    Sep 2012
    Sutton, Surrey
    3,752
    Did you put that on? Was it bought as a nova conversion? Or was it a vw golf 1.6 converaion carb that hasnt been rejetted?
    Feb 2014
    Wrexham
    573
    That's way too rich....nearly 9% on the CO is way too high. The hydrocarbons should come down under the 1200 limit if you get the mixture sorted. If you can find the mixture screw see how many turns it is from the zero setting.
    just as a starter if it's 3 full turns put it at 1 full turn and see if the engine will start and run...if not go to 2 full turns, if ok then try 1 1/2 turns.
    You really need a garage to give it a set up...obviously some of the jets may well be too big and may need reducing etc.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    how does it feel when driving? does it struggle to rev/bog down then shoot off?
    Jul 2008
    Greenhithe
    1,614
    I’ve got the jetting info for the 1.3 and 1.4 if you need it. There is a screw on the side of the carb to adjust the mixture. Normally turn it in abit will help but must be jetted correctly first.
