Results 1 to 6 of 6
Thread: Hazard lights not working ....
    Jun 2016
    Huddersfield
    231
    Default Hazard lights not working ....
    Hi so I've connected battery up today to see if all electrics work and I so far have no hazard lights . I removed a toad alarm from the car . The hazard light switch illuminates but will not work. Indicators work ok but if you put hazard switch on they don't work but I presume that part is correct.
    Please can anyone help . Are the mk1 hazard switches prone to failure???
    Sep 2012
    Sutton, Surrey
    3,752
    Are you sure there wasn't a splice in the alarm to flash the indicators? Might be worth checking
    Jun 2016
    Huddersfield
    231
    Quote Originally Posted by millworm View Post
    Yep there certainly was I think 2 of the main wires were cut and it then went through alarm so wen I removed alarm I cut away and connected them back together. Can't remember colours it was over a year ago.
    I've just picked up a new hazard switch so I'll try that hopefully Tommorow or Monday. If not it's a case of Tracing wiring etc.
    Feb 2014
    Wrexham
    573
    Relay seems to stick when not used for a while. Worth a look
    Jun 2016
    Huddersfield
    231
    Quote Originally Posted by Jonesfach View Post
    Cheers for suggestions sorted this it was fuse in fuse box. It was missing 🙈
    Feb 2014
    Wrexham
    573
    Quote Originally Posted by SRsam View Post
    Cheers for suggestions sorted this it was fuse in fuse box. It was missing 
    Yes that might help !
