Results 1 to 8 of 8
Thread: Ignition timing E16SE
    Newbie
    Feb 2016
    Italy
    16
    Default Ignition timing E16SE
    Hi all,
    I read here in the forum the correct way to set ignition timing is to unplug throttle switch, bridge the wires, and set the timing. Correct?
    Where the throttle switch is? Is it behind intake manifold? Which wires I have to bridge? All wires of the plug? Then I must rotate the dizzy cap to adjust the timing. 10 degrees BTDC, but 7 If I run unleaded. Is correct? I run 100 octane unleaded fuel.
    Sorry for the questions, but I want to be sure to set perfectly the ignition timing (not me, the mechanic)
    Thanks a lot
    Newbie
    Feb 2016
    Italy
    16
    Anyone can help me?
    Club Member Club Member CorsaBBoomer's Avatar
    Oct 2006
    Belgium
    396
    I think there is no better option then a timing light (strobe)
    Opel Corsa 1.6 Michalak 1986 : http://www.pngclub.com/forum/showthr...ect&highlight= Yes, it's a convertible with a hard-top!
    Opel Corsa 1.0 1983 "Josefien": http://www.pngclub.com/forum/showthr...ien&highlight= Miss I-Went-International
    Opel Corsa B 1.5TD 2000 "Bertha"
    Citroen AC4 1929 "Clarice"
    Newbie
    Feb 2016
    Italy
    16
    I have it
    Newbie
    Feb 2016
    Italy
    16
    Hi all
    I tried to set ignition timing. But I didn't note difference between disconnect throttle switch (and bridge terminals) and not. When I rotate the distributor, the idle speed increase or decrease. I think is correct. Or not?
    Newbie
    Feb 2016
    Italy
    16
    Hi guys,
    Sorry If I come back to this argument, but I'm driving crazy with ignition timing.
    E16SE engine. I have the crank pulley with only one notch. I have another notch on the belt cover. When these 2 notch are aligned, how many degrees have the ignition timing? Five? Ten? I read on the haynes but didn't find this value. I have the green haynes, not blue.
    Thanks
    Sep 2012
    Sutton, Surrey
    3,752
    When the 2 notches are level it should be 10deg
    Newbie
    Feb 2016
    Italy
    16
    Quote Originally Posted by millworm View Post
    Thanks! With a strobo gun which can increase/decrease advance degrees, can I read the timing exactly?
