Results 1 to 7 of 7
Thread: 7 1/4 clutch
    Sep 2012
    Sutton, Surrey
    3,752
    Default 7 1/4 clutch
    Anyone running one? I've got a flywheel drilled out and just wondering wether to bother using it or not
    leeds
    1,336
    3 Post(s)
    Can have problems with the height, the cover can touch the bearing support on the gearbox secondary shaft inside the bellhousing, worth checking measurements...
    Jun 2007
    865
    I use one on mine ,not a road car though ,like Ben says you have to be careful on clearance
    Sep 2012
    Sutton, Surrey
    3,752
    Worried if it'll squeeze in an f16 then, what box you running?
    Jun 2007
    865
    Quote Originally Posted by millworm View Post
    F13, not sure how much bigger the 16 is, but it’s tight in mine ,not sure what benefit it would be on a road car tbh
    Sep 2012
    Sutton, Surrey
    3,752
    Fair enough mate, more of a case of just having most of the bits and wondering wether it'd be worth it apposed to really needing it
    2,618
    Could make a 4MM plate spacer for the box then just fettle the 2 mounts
