Looking for a genuine engine for my GSi rebuild as i have a E16se which i believe is for GTE and not correct for GSi
C16se wanted can be bare block as i have everything else
Thanks
Thanks
Thought they were both the same motor ?
From what iv read E16se with round top cam belt cover were in GTE and some early GSi had E16se with a square top cam belt cover
C16se was the engine then put in the GSi
I could be wrong
but the engine i have is an E16 with round top cambelt cover which i believe would be incorrect to fit in my GSi
Im sure the belt cover will just unbolt and be replaced with the kind you want if its the cover thats a problem .
There is a full motor on ebay about 450 not sure which kind like
http://www.ebay.co.uk/itm/Vauxhall-N...-/173117133012
Thanks mate
c16se was only in the later Gsi - so it depends what year yours is
99% a e16se then - depends when it was registered I guess
I have a 1988 Corsa A GSI completely original fitted with a e16se round top cam belt cover.
