Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Gaz coilovers
    Aug 2008
    blackpool
    3,415
    Default Gaz coilovers
    Hi I have a set of front Gaz coilovers can any one tell what drop these are. There don't seem to be many threads on the body's. I have dropped the car on full drop and it don't seem low enough.
    Here is a pic of the coilover.
    Sent from my SM-A520F using Tapatalk
    Sep 2005
    brotton , saltburn by the sea
    1,877
    Loose those strut tops mate and fit alloy type ones will get alot more drop as you dont use all that rubber n spacers n stuff on the top.
    Aug 2008
    blackpool
    3,415
    Worth a shot how much are alloy top mounts. ? Only thing is when jacking car up the spring is completely loose as the piston is at full travel with the standard top mounts won't It be worse with the alloys ones. ?
    Sep 2005
    1,877
    Wind it up as you will havealot more play without the standard tops otherwise buy some helper springs. The tops are about 100 from gaz and obp
    Aug 2008
    blackpool
    3,415
    Ok thanks pal.
    User Club Member
    Jan 2005
    brotton (north east uk)
    442
    bit off topic but lookingat the picture you have posted you are missing a locking ring from under the spring there should be a pair that lock together to lock the platform at adetermined high not just a single one which will allow the spring platform to move
    Sep 2012
    Sutton, Surrey
    3,752
    As stated should have 2 rings like this mate
    Sent from my SM-G930F using Tapatalk
    Aug 2008
    blackpool
    3,415
    Thanks for the pics and advice will get on to the seller about these.
    Aug 2008
    blackpool
    3,415
    Just had another look and these have a locking grub screw in the collar to lock them.
  10. #10
    Sep 2012
    Sutton, Surrey
    3,752
    Mine have that too and still have 2 rings
