Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Standard c20xe on jenvey DTH advice
  1. #11
    May 2016
    147
    Thanks Stuart, some useful info there I shall mention it when it's time for setting up!
    Another question is the water fitting on the bodies. They came with no push on fitting fitted! Will I need to drill and tap for the push on brass fitting, or will it be okay blanked off as it is?
  2. #12
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    If it's the sbd inlet (Jenvey) then you can buy the water inlet to add on I think? Unless you have one that's been blanked?
  3. #13
    May 2016
    147
    Are we on about the same part? I have blocked off the 3 way hose on the back of the engine, I'm on about where the top altenator adjuster is. Mine has nothing there and the rear of the bodie body where the gasket sits has no receses. I have seen where people have drilled and tapped a brass fitting in there and some without it.
  4. #14
    May 2016
    147
    Mine are direct to head so no manifold
