Anyone have a flywheel, 1.2, 1.3, 1.4 or ideally from a 1.6, believe they are all the same.
8v are all the same, flat type.
I'm sure I've got a few in the shed, drop me an e-mail.
To contact me please use E-MAIL to colinesmith@aol.com.
thousands of Nova (plus other Vauxhall and motorsport parts) available.
That's isn't right. They has different diameters.
The 1600 has 285mm
The smaller than 1400 has 250mm
the 1400 gives with both 250 and 285.
But you can't fit a small one on a 1600, because the starter will not work on them.
And a big one you can't fit, because the space is to small.
So you must have a look, which one your engine now has and you need the same diameter.
Thanks for the info.
