Results 1 to 3 of 3
Thread: C20let clutch cover bolt torque settings please
    Sep 2005
    brotton , saltburn by the sea
    1,877
    Default C20let clutch cover bolt torque settings please
    As above needed asap please daft question but cant seem to find the correct settings anywere.
    Cheers
    Feb 2015
    NL
    159
    hope this will help:
    torque settings:
    valve cover (-Set)
    8 Nm
    camshaftbearings
    M6 10 Nm
    M8 20 Nm
    camshaft pullies
    Trap 01 50 Nm use new bolds and nuts
    Trap 02 60°
    Trap 03 15°
    Spannerroll – Multi-riem/V-snaar
    25 Nm
    Spaninrichting Multi-riem/V-snaar
    20 Nm
    Spanrol – tandriem
    from 1993 25 Nm
    till 1993 25 Nm + 45° + 15° use new bolts
    Distributieriemkap
    8 Nm
    Cilinder Head bolts (use new bolds)
    Trap 01 45nm
    Trap 02 60graden
    Trap 03 60graden
    Trap 04 60graden
    Trap 05 45graden on hot engine
    or: 3x 90degrees per trap
    inletmanifold
    22 Nm (use new bolds and nuts).
    exhaustmanifold
    sparkplugs
    25 Nm
    knocksensor
    20 Nm
    crankshaft pulley
    20Nm
    crankshaft – main bolt
    M12 130 Nm + 40-50° Nieuwe bouten gebruiken.
    M16 250 Nm + 40-50° Nieuwe bouten gebruiken.
    clutch pressureplate
    15 Nm
    flywheelbolts
    Trap 01 65 Nm Nieuwe bout(en) en moer(en) gebruiken.
    Trap 02 30°
    Trap 03 15°
    oil plug
    hex- 45 Nm
    Torx – 10 Nm
    Oil filter
    15 Nm
    connecting rod bearing
    Trap 01 35 Nm use new bolts and nuts
    Trap 02 45°
    Trap 03 15°
    main bearings
    Trap 01 50 Nm Nieuwe use new bolds and nuts
    Trap 02 45°
    Trap 03 15°.
    afr sensor
    30 Nm
    Sep 2005
    1,877
    Top man
