Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: E16se timing marks
    blackpool
    3,414
    Default E16se timing marks
    Iam struggling to set the timing up on on my e16se. I've got the mark on the crank sprocket lined up with the mark on the oil pump which is 6 0clock. The cam pulley is lined up with the mark on the back plate. I've locked the flywheel problem is every time I tension the belt and spin over the engine it goes out a tooth every time. Any help would be great
    Dec 2011
    Fife,Scotland
    1,138
    Is the belt the correct length?
    blackpool
    3,414
    Iam pretty sure it is. 104 teeth seems to be right after checking.
    blackpool
    3,414
    Timing sorted now but car is being hard to start and when it does it's missing bad and over fueling. It runs sweet as at 2-3000 rpm? Any ideas. Maybe a dodgy sensor somewhere? Also fitted a new fuel pump still the same.
    Senior User mowgli's Avatar
    35,194
    Ignition timing is & usually gets advanced way too much
    Sent from my SM-G388F using Tapatalk
    blackpool
    3,414
    How do I sort this ? Car don't want to start.
    35,194
    Do you have the light blue Haynes book with the section on E16SE in chapter 13? It's all in there
    blackpool
    3,414
    No I don't you know where I can get one ?Cheers
    35,194
    EBay is good
    blackpool
    3,414
    Will take a look cheers.
