Results 1 to 1 of 1
Thread: Oil Leak after Head Gasket replacement
    Newbie
    Oct 2017
    8
    Default Oil Leak after Head Gasket replacement
    Hello from Australia!
    I am having issues with my Holden/Opel/Vaxhaull Combo 1997 with a C14SE engine.
    I had issues with an oil leak from the front of the head as the previous owner wasn't aware of the car over heating. I have left a previous post about fixing the overheating issue but after replacing the 3 pin sensor and the 2 pin sensor as well , I am just gona leave a manual switch inside the cabin to the fan.
    While doing the head gasket I did not notice anything out of the ordinary and the block did not seem to have warped.
    I torqued everything correctly as well as degress but I noticed that I am getting an oil leak where the fly wheel is and I am soo confused.
    https://youtu.be/r69snYuN5zM
    Any ideas on why the leak or where it is coming from?
