Results 1 to 8 of 8
Thread: Arp clutch bolts??
    Sep 2005
    brotton , saltburn by the sea
    1,877
    Default Arp clutch bolts??
    Anyone know if these are avalible for c20let
    Cant seem to find a set . If not what would you recomend for big power
    Jan 2004
    Ash vale, Hampshire
    1,471
    If you mean flywheel bolts you can get them on eBay.
    Jan 2004
    Ash vale, Hampshire
    1,471
    I've just had a look and I can't see pressure plate bolts for sale, so that's probably what you was after. Sorry
    Sep 2005
    1,877
    Yea I have the flywheel bolts its the clutch ones I need now . I will have to ring the clutch company and see if they can provide me with somthing suitable
    North Events Co-ordinator Moderator boffer8's Avatar
    Feb 2006
    leeds
    1,336
    3 Post(s)
    What size holes have you got? most standard ones are M7 iirc, but drill a new hole further round and fit M8's with 10.9's, wont go anywhere then, that's what i run
    If Carlsberg did Motor clubs, then IDMC would probably be the best motor club in the world.
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    Or the posh flywheels are sometimes M8s?
    I've never heard of ARP clutch cover bolts, are the standard ones an issue ever?
    Sep 2005
    1,877
    Iv never heard of them being an issue before mate .
    However you know what its like , il hang my self if I have done every bolt I can in arp and I scrimp on the clutch cover and it gives up
    Feb 2006
    2,618
    Repeatability is important too when locating the clutch on the flywheel if it's balanced; M7 is fine if you dowel the flywheel & pressure plate as this ensures it only goes on in the one location (placed where it was when balanced). That said nothing wrong with going M8 as bigger is stronger & more available size. If you chase revs past 8k then ditch the cast flywheel it'll probably shat itself otherwise. You can go ARP with the flywheel to crank bolts & that's a pretty particular method of apply greases then loctite, torquing etc underlining the importance.
