Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
Thread: Help! Nova gte engine wont start.
  1. #21
    Aug 2008
    blackpool
    3,414
    No it's a 1.2 carb nova with the e16se engine and loom
    Sent from my SM-A520F using Tapatalk
  2. #22
    Club Member Club Member duick's Avatar
    Jan 2007
    Luxembourg
    847
    Is it a Bosch or Siemens system? the Siemens one has also a crank sensor, maybe that one is faulty?
  3. #23
    Aug 2015
    Derby
    439
    Certain looms (1.0 and some 1.2) have a resistance wire in them which would need removing or bypassing. I got a perfect 1.0 loom for my Sport resto (as the original had been butchered) and we needed to remove this cable - referred to as R1 in Haynes wiring diagrams.
  4. #24
    Feb 2007
    16,486
    Quote Originally Posted by duick View Post
    No Siemens loom I've ever had has had a crank sensor,the later silver ecu coilpack looks might do but Siemens doesn't.
  5. #25
    Aug 2008
    blackpool
    3,414
    Defo no crank sensor on this engine or loom. Yeh heard about the wire you have to remove on 1.2 engines don't think this is the case of mine.
  6. #26
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    Where did you get the +ve from for the ecu?
    Sent from my SM-G388F using Tapatalk
  7. #27
    Aug 2008
    blackpool
    3,414
    All I've wired up as information ive read up on is :
    Thick red/blue - pump
    Green - clocks
    Black- thin 1.2 coil wire
    Thick red/ecu - positive battery.
  8. #28
    Apr 2002
    35,194
    That should be ok. You could have the timing way out. The module under the coil can play up. The cts is worth checking too.
  9. #29
    Aug 2008
    blackpool
    3,414
    Checked the timing it's right even if it was out it would attempt to fire up but run like crap surely.! Yeh what's best way to check the module? The cts is a brand new Bosch item so should be good. !
  10. #30
    Apr 2002
    35,194
    I just swapped mine.
