Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Thread: Help! Nova gte engine wont start.
  1. #31
    blackpool
    3,415
    Will try another relay and go from there. Is it worth removing the fpr and checking ?
  2. #32
    Senior User mowgli's Avatar
    35,194
    From bitter experience, check everything.
    Sent from my SM-G388F using Tapatalk
  3. #33
    blackpool
    3,415
    Will do cheers for the help.
  4. #34
    brotton , saltburn by the sea
    1,877
    You tryed easy start yet mate trust me it will make things alot easyer to figure out whats going on .
  5. #35
    blackpool
    3,415
    It's on my list to do pal when I get a moment .
  6. #36
    blackpool
    3,415
    Update fit new relay still the same. Found a tin of easy start it tried a little to fire not much. I've took rail off to see if it's blocked and cleaned out fpr to see if any difference just checking everything. Will refit tomorrow and go from there.
  7. #37
    1,877
    It should run smooth on easy start alone mate get a friend to squirt it in blasts as you turn it over . I had a gte that did this once before but I cant remember what the fault was now . Had spark and fuel but would only start after a spray of the good stuff
  8. #38
    blackpool
    3,415
    I did that pal had a friend crank as I sprayed it in as said only slightly attempted to start.
  9. #39
    Club Member Club Member duick's Avatar
    Jan 2007
    Luxembourg
    847
    Did you measure the fuel pressure? is it ok?
    Near the fuel pump, there's a fuel return valve, that keeps the pressure on the line. Can also cause trouble
  10. #40
    blackpool
    3,415
    Iam not running the standard gte fuel pump .
