Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: Help! Nova gte engine wont start.
  1. #51
    Senior User mowgli's Avatar
    35,194
    It should be pissing out
    Sent from my SM-G388F using Tapatalk
  2. #52
    blackpool
    3,415
    It wasn't probably cos of the fpr was peeing it out.
  3. #53
    brotton , saltburn by the sea
    1,877
    If its pushing fuel out of the fpr . I would realy check you have the pipes the right way around mate
  4. #54
    blackpool
    3,415
    I have checked pal. The one under the fpr is the return the other is the inlet. I found that out on here .
  5. #55
    blackpool
    3,415
    Anyone confirm that's right ^^^^?
  6. #56
    blackpool
    3,415
    Update she is a runner I put a new fuel reg on and started up. The engine sounds sweet but running a little rough. It's idiling a little rough hunting about. Also Iam a bit concerned about the oil when I dipped the oil it's creamy could this be due to condensation?
  7. #57
    blackpool
    3,415
    Looks like head gasket has failed. Dropped oil and it's like a container of salad cream. So pissed off with this Bastard engine. I torqued it all down correctly it's only ran for 10 mins max and this has happened.
  8. #58
    Feb 2007
    16,486
    Did it have coolant in?
    head gasket on right?
  9. #59
    blackpool
    3,415
    Yes no mayo in coolant pipes just a sump full of mayo. Head gasket was on right. What else could be the cause? Back to square 1 again now. Strip down commence....
  10. #60
    35,194
    Is the coolant disappearing? If not, then just get some miles on it before stripping it
