Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Help! Nova gte engine wont start.
    Aug 2008
    blackpool
    3,415
    Default Help! Nova gte engine wont start.
    I've checked its got spark. Earths are fine. All is happening is will crank over fine wont attempt to fire up. Iam getting fuel to the rail. Plugs are dry. Just fitted this to a 1.2 carb shell. Running gte tank. One thing I've noticed is pump sounding like it's struggling when I turn on ignition to crank. Any help would be great.
    Sep 2005
    brotton , saltburn by the sea
    1,877
    If the rail is at pressure the pump will die down mate . Press the valve n make sure its at full pressure there . If you have fuel and a spark it should fire in some kind of way even if the timing is miles out
    Aug 2008
    blackpool
    3,415
    Where is the valve on the rail couldn't see it. ?Cheers for the help
    Aug 2008
    blackpool
    3,415
    Just checked the ecu loom plug and it has 17 pins but the ecu has 25 is this correct. ?
    Sep 2005
    1,877
    I have a couple of looms I think mate if you get totaly stuck for plugs or somthing like that .
    Aug 2008
    blackpool
    3,415
    Thanks pal. Need to know if they are all 17pin on the ecu plug. If anyone can help.
    Aug 2008
    blackpool
    3,415
    Any ideas?
    Sep 2012
    Sutton, Surrey
    3,752
    Are the fuel lines defo on the right way? Also had a similar issue on an xe where it was doing the same, unplug all the injectors and crank for a few seconds, plug them in again and it ran. Don't know why but it works for some reason
    Aug 2008
    blackpool
    3,415
    Yep defo on the right way round. Will try unplugging injectors and see. Iam at my witts end with it now. Got a new fuel pump relay coming so will try that too. Cheers
  10. #10
    Sep 2012
    Sutton, Surrey
    3,752
    If it's like an xe the relay will control injectors too. Assume you have power to them and earths I know you said that you did already. Mine had power to them but didn't fire, did what I said above and it worked. Makes zero dance as to why but I wasn't complaint
