So I've stripped my donor Calibra to transplant everything into the Nova, mounts, shafts and hubs sorted but I'm kinda stuck with the wiring in of the transponder.
Also, where the loom enters the engine bay from the ECU there are 3 bunches of wires that cross along the bulk head to the engine bay fuse box. 1 connects directly to the battery terminal, one is a single thick black wire which splits, ie, has a plug to unplug it and the next had the fuel pump coloured wire and an earth/brown wire.
Where do these go and is there a diagram for wiring up the transponder anywhere?
