Results 1 to 5 of 5
Thread: E16se wiring
    Aug 2008
    blackpool
    3,415
    Default E16se wiring
    Right got the engine in what's needed to make it run wiring up wise? Car is a mk1 1.2 carb. Got the the tank and pump. I have a black wire near the coil. Sure someone told me it's 3 wires to make it run?
    Aug 2008
    blackpool
    3,415
    Anyone help.?
    Aug 2008
    blackpool
    3,415
    I've had a look think iam right. The plug on the loom
    Red blue = fuel pump
    Black = switched live
    Big red = battery for ecu?
    Can someone confirm Iam right!
    Also does this black wire near the coil go to the black on the gte loom plug?
    Sent from my SM-A520F using Tapatalk
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Yep all correct - green is rev counter and blue is temp
    Aug 2008
    blackpool
    3,415
    Cheers
