Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Mk1 nova project
  1. #51
    blackpool
    2,761
    After more digging out filler on the pillar it looks like the door has been hit bending the pillar area making the door fit bad. So here are some pics. Anyone scrapping a shell they could cut the area out for me ? Cheers.
    Sent from my SM-A520F using Tapatalk
  2. #52
    Senior User Club Member Rickyb's Avatar
    Apr 2007
    blackpool
    3,051
    looking good buddy.
  3. #53
    blackpool
    2,761
    Cheers pal. Have you a scrap shell with a good n.s pillar?
  4. #54
    blackpool
    2,761
    Been busy drilling spot welds out. Quite a few I must say. Flitch panel removed. Then came cutting the pillar out.
    Inner sill is minty fresh behind as is the rest so all good. On with the repair pillar next weekend also need some gas to weld it on. Will update next week.
  5. #55
    blackpool
    2,761
    Update. Need some help on this. I've found a other pillar which I have welded in but the problem is the door gap is exactly the same as before. Iam at a loss to what is causing this! Any one shed some light on it. Here is a pic. It's tight at the top and wide as it meets the lower point of the pillar. Also I have a big wing to door gap.
  6. #56
    Club Member Club Member total_vauxhall's Avatar
    brotton , saltburn by the sea
    1,359
    Is it a genuine door .
    E318 FPN J87 TGS E
  7. #57
    blackpool
    2,761
    Yes pal I've even tried a spare door on and it's the same.
