Page 6 of 18 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 177
Thread: Mk1 nova project
  1. #51
    blackpool
    3,415
    After more digging out filler on the pillar it looks like the door has been hit bending the pillar area making the door fit bad. So here are some pics. Anyone scrapping a shell they could cut the area out for me ? Cheers.
    Sent from my SM-A520F using Tapatalk
  2. #52
    Senior User Rickyb's Avatar
    Apr 2007
    blackpool
    3,057
    looking good buddy.
  3. #53
    blackpool
    3,415
    Cheers pal. Have you a scrap shell with a good n.s pillar?
  4. #54
    blackpool
    3,415
    Been busy drilling spot welds out. Quite a few I must say. Flitch panel removed. Then came cutting the pillar out.
    Inner sill is minty fresh behind as is the rest so all good. On with the repair pillar next weekend also need some gas to weld it on. Will update next week.
  5. #55
    blackpool
    3,415
    Update. Need some help on this. I've found a other pillar which I have welded in but the problem is the door gap is exactly the same as before. Iam at a loss to what is causing this! Any one shed some light on it. Here is a pic. It's tight at the top and wide as it meets the lower point of the pillar. Also I have a big wing to door gap.
  6. #56
    brotton , saltburn by the sea
    1,877
    Is it a genuine door .
  7. #57
    blackpool
    3,415
    Yes pal I've even tried a spare door on and it's the same.
  8. #58
    Newbie Club Member
    Aug 2018
    lancashire
    27
    Looking good mate.
  9. #59
    blackpool
    3,415
    Update got new pillar welded in and skimmed up. Got gaps a lot better aswell not 100 per cent but happy now. Next up weld up the flitch panel and finish 2k priming and fit new screen as cracked the hell out of the other one. Also got a fuel leak to sort.
  10. #60
    blackpool
    3,415
    Flitch panel on and seam sealed. Carpet back in will get some more sorted later on.
