Results 1 to 7 of 7
Thread: Coilovers question
    Aug 2008
    blackpool
    3,415
    Default Coilovers question
    I ve got some coilovers purley so I can slam it on my comps but as they come with a slotted hole for camber adjustment which I don't want would camber bolts sort the camber out until I can set it up when she's back on the road.
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Yes.
    Aug 2008
    blackpool
    3,415
    Ok cheers
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    Not sure what you're asking, but I would not run slotted holes AND camber bolts. Fit them all the way in or all the way out so they're roughly matched between sides.
    Sep 2005
    brotton , saltburn by the sea
    1,877
    If you dont like the slots mate set it up how you want then weld a thick washer eather side to keep it fixed .
    If them slots shift at speed it doesnt only ad camber it will alter the steering potentionaly throwing you off the road.
    Aug 2008
    blackpool
    3,415
    Yeh thinking about it gonna weld a washer either side to do away with the slotted hole. Cheers
    Sep 2012
    Sutton, Surrey
    3,752
    Just be mindful if your welding a shock it is full of compressed gas or oil...
