Results 1 to 6 of 6
Thread: 1.6i 8v conversion
    Apr 2017
    13
    Default 1.6i 8v conversion
    hi not sure if this is in the right place correct me if im wrong
    i have currently just put a 1.6i C16SE engine with 5 speed box into my vauxhall nova 1.2i.
    the car runs fine im have a few issues with it stalling when i come to a stop! i have wired in the speed sensor but still have the same problems anyone got any advise for me on what i can do to fix this problem.
    13,604
    Did it idle successfully in the donor car? If yes, I would look for air leaks. I didn't think they needed any special wiring affecting idling like the 16vs.
    Apr 2017
    13
    yea the engine in the otther car was fine i drove it 90mile back to where i live... where would the air leak be and whats the process of checking?? the nova idles perfect untill driven
    Sep 2012
    Sutton, Surrey
    3,752
    Check for air leaks by spraying some wd40 around the gaskets ect making sure it can't get straight into the air filter obviously and listening for a rev increase. Check your also getting a live and earth at speed sensor. Black is switched live and brown is earth.
    Apr 2017
    13
    speed senor checks out fine when i check it the other day.. ill try an search for air leaks see what i come up with... if no air leaks are fount what else coukd this be?
    Club Member Club Member stuartyj21's Avatar
    Aug 2007
    northern ireland
    1,672
    check if the timing need slightly adjusted.
    nova gsi project : http://www.pngclub.com/forum/showthread.php?t=87640
    Rolling road readout- 104.8 bhp/117.4 lbft
    astra gsi project:http://www.pngclub.com/forum/showthread.php?t=167790
