Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Cable Gear Change Conversion
  1. #11
    Apr 2011
    wiltshire
    1,938
    Quote Originally Posted by toymex View Post
    Are you sure something isn't moving on weight transfer that is making it difficult, I found that the helicopter joint was touching the turret very slightly occasionally which was causing a problem which was amplified by very slight movement of the box,I have solid/ updated mounts too!
    It was, so i made new engine mounts. It's 10 times better now but still an issue. The engine / gearbox doesn't move at all.
  2. #12
    Jun 2007
    865
    I also found that the bush in the turret wears quickly allowing slight movement
  3. #13
    Newbie
    Jan 2012
    48
    I did a how to guide on this a while back. Can supply cables if need be to....
    http://www.pngclub.com/forum/showthread.php?t=211964
    Sent from my SM-G900F using Tapatalk
  4. #14
    Club Member Club Member novarally's Avatar
    Jun 2002
    Poole, Dorset, United Kingdom
    8,490
    Quote Originally Posted by C20 YOB View Post
    Many thanks for that, I managed to miss your article before.
    Any chance you could drop me an e-mail please as there's a few bits I'd like to discuss. Thanks;
    colinesmith@aol.com
    To contact me please use E-MAIL to colinesmith@aol.com.
    thousands of Nova (plus other Vauxhall and motorsport parts) available.
  5. #15
    Feb 2006
    2,618
    You can get a different design of turret shifter that'll go straight onto the box top & if you're not on an F20 casing the O.E cable bracket can be rewelded for a near perfect route.
    I've just done a conversion at the turret end to rose joints; I have had a standard end bushing pop off when shifting in anger, meaning it can't happen again & less slop. That said even as it was the setup can easily beat synchros. Very precise & IMO a CAE probably not needed.
  6. #16
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Broad, any photos of yours?
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  7. #17
    North Events Co-ordinator Moderator boffer8's Avatar
    Feb 2006
    leeds
    1,336
    3 Post(s)
    How is yours routed colin?
    Mine is quite direct as it goes over the rack and down to the turret. I don't have any shift issues with when using mine aggressively on a hillclimb and must say i'm yet to beat the synchros....
    Ryan Brassington is doing the conversion at the minute with Vectra parts so will be interested to see what he says using the std vectra parts throughout.
    If Carlsberg did Motor clubs, then IDMC would probably be the best motor club in the world.
  8. #18
    Jun 2002
    8,490
    Quote Originally Posted by boffer8 View Post
    I've picked up all the bits from a Vectra C with F17 gearbox and cable change.
    It's all been mocked up on the floor to a spare F10 box, and seems to work really nicely. I'll post up a few photos soon.
  9. #19
    Jun 2002
    8,490
  10. #20
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Looks good. I do really like the idea of this on mine.
    Far from suicidal
